Error after updat revit 2018.1
5 ANTWORTEN 5
Nachricht 1 von 6
391 Aufrufe, 5 Antworten
"A serious error has occurred. The current action has been cancelled. It is strongly recommended that you save your work in a new file before continuing.."
This error occurred when wrong in sketch environment, and revit auto exit sketch environemt immediatly.
5 ANTWORTEN 5
Nachricht 2 von 6
sureshchotrani
als Antwort auf: Anonymous
Welcome to the community:)
When you say "This error occurred when wrong in sketch environment, and Revit auto exit sketch environment immediately." What wrong are you doing?
Does it happen every time you are in sketch?
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Nachricht 3 von 6
als Antwort auf: sureshchotrani
- My English is very bad, so maybe very hard to understand what i say, sorry :leicht_lächelndes_Gesicht:
- In revit project, i try create Model in place and begin with sweep ( extrusion, swept blend...), any wrong oparation, such as  an error : " lines must be in closed loop..", then instead of continuing sketch with press continue button as previou revit version, that error comes with the question "Would you like to save recovery file". Whether you choose Yes or No button, revit will also exit sketch environment.
- This error continues appear when you create floor,... or whatever has a sketch mode, even in family environment.
- This is very uneasy.
Nachricht 4 von 6
sureshchotrani
Kindly help with below things
Is this happening in every file or in particular Revit file or project?
What windows are you working on? Meaning windows 7, 8, 10? What graphic card is installed?
Do you have Revit 2017 install & are you facing similar issues in Revit 2017 as well?
Nachricht 5 von 6
Hi all,
i don't know what happen with my revit. The next day, that error doesn't happen with Revit
Nachricht 6 von 6
sureshchotrani
Let us know if this comes up again.
If its file specific then kindly Audit it regularly, https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2017/...
