Hi all,
After i installed revit 2022 i got the following error (see pic).
Unfortunately have not been able to resolve it but luckely am able to work in revit 2022.
When installing i did leave the windows defender on active so that could be the culprit (has been in the past).
Anyone any idea to get this resolved? (autocad 2022 is prone to crash to desktop after this error)
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Unfortunately the problem is the same for acad 22 and revit '20. So i would like the find a solution without deinstalling acad and both revit versions...also autodesk desktop app is not responding...
you can try these and see if helps. thanks
There was no problem with installing Revit or autocad but when opening these programs then the issue (errors) started
Thank you this article was what i needed. Aomei was the culprit: after uninstalling aomei the problem is gone!
