I design the perimeter from staircase underneath dwg to build my own staircase, by which, for the particular shape of the wall structurals along the path, should probably be better as solution. Which trick would be beneficial to solve Error 1 in designing with personal shape ?
Thank you in advance.
Best Regards
Are your Boundary Lines closed? There must be no gap between them.
The start and end must be a riser line.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
I am waiting to attach the linked file, that is bigger than the 71 MB, Well, yes I checked, The start riser and end one are riser lines.
Model the stair with 3 normal runs + 2 landings, then convert the runs and landings to sketch and edit their shape.
Check your Base Level and Top Level when placing the stairs. Also when creating with profile pay attention to the boundaries to be closed. The area where you have to pay attention is in the screenshot.
Is always a roulette with these staircases, I remember I checked many times, I think would be better to don't pick lines from dwg but create as simplest as possible. Another doubt: But when decided to give multiple levels of storey it seems You couldn't go back and modify the drawing of the stair. This just because It has being created with an uncorrected plan scheme.
I don't know if its clear what I am saying but attaching the file would be a long procedure..It's just beacuse the screenshot tells me that out from connect levels, ther's no option to go back ( out from undo, of course) and modify drawing.
