I have y/n parameter X, user input parameter Y (dimension), and a, b, c, d.
I wd like to make a=b=c=d=Y once X is ticked.
If X is not ticked, a, b, c, d have their own dimensions values.
I wrote
if(and(X, a=b=c=d=Y,))
and of course it s not working. Can you help ?
Gelöst! Gehe zur Lösung
Gelöst von yes_and_no. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
https://www.revitforum.org/node/1126
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-A0FA7A2C-9C1D-40F3-A808-73CD0A4A3F20
a=if(X, Y, [some other value])
b=if(X, Y, [some other value])
c=if(X, Y, [some other value])
d=if(X, Y, [some other value])
[some other value] is either a number or another parameter name.
It seems I need a set of extra 4 more parameters.
I wd rather copy n paste directly the values on the properties tab.
You would rather do a task who knows how many times than add 4 extra parameters?
The chance this family has 4 equal dimensions is less than the otherwise.
I thought it can be a simple way to give it an extra choice as that, for a schematic start.
But it seems give it the same default dimensions achieve the same intent.
