AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Equal Panel Width of Curtain Wall from Center to Center of Mullions
8 ANTWORTEN 8
Nachricht 1 von 9
hliS658H
563 Aufrufe, 8 Antworten
Trying to get the curtain wall has equal width from center to center of the mullion, but whenever I click EQ, the red center lines will go to the most outside and the dimensions of the side panels  go to the edge instead of the center of the mullion. But of course, there are no hidden center lines on the border frame, that is why I had to draw lines there, even if I pinned the red center lines, it didn't help.
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: hliS658H
Edit Curtain wall type and tick the box Adjust for Mullion size under vertical grid and horizontal grid.
Nachricht 3 von 9
hliS658H
als Antwort auf: ToanDN
It didn't help.  Revit just moves the center line, one to the edges,  the other  to the middle of the panel.
Since the center lines are manually added, is there a way to move the grid line of the frame from edge to its center? Actually, I don't see grid line in frames, only the mullion between frames
Nachricht 4 von 9
Mike.FORM
I use this line base detail item to set my spacing. set the instance parameter for mullion width and how many mullions I want and then I can align my mullions to the lines created.
Nachricht 5 von 9
Use Quad Corner for End mullions.
Nachricht 6 von 9
hliS658H
Can not open your file in 2023 Revit
Nachricht 7 von 9
hliS658H
als Antwort auf: Mike.FORM
can not open your file in 2023 revit
Nachricht 8 von 9
Mike.FORM
Here is a 2023 version.
Nachricht 9 von 9
2022.
In Foren verƶffentlichen
