I know how you create equal dimensions with a string of dimensions but how do you maintain equality when they are separate dimensions?
What I want to do is ensure the two dimensions marked in red are equal without having to actually work what it is and type it in!!
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Is it a family? Then a string of EQ EQ to the center reference plane of the family should suffice.
You cannot have revit maintain equality in the way you are looking for. However, if absolutely necessary due to firm-specific graphic standards, there is a way to get the desired results.
This will give you a window that stays centered on the wall, with the graphic dimensions on either side. Please note, the manually set "EQ" text is prone to resetting if you edit the host wall or change the window family.
how about using Global Parameters , as shown in my screencast?
https://knowledge.autodesk.com/community/screencast/d5eee51d-dbbb-4ec3-8c51-cde938886006
Constantin Stroescu
you can use a Calculation formula for the Dimension:
Constantin Stroescu
