(EQ) Toggle Dimension Equality
Any ideas why when I click on EQ symbol of a dimension,  it says constrains not satisfied while working inside a group?
when the elements are ungrouped, it is working fine.
Erense
Is there only one instance of the Group placed?
If there are more then one i can imagine it won't work unless you 'edit' the group to update all group instances.
If you only want to update one of th einstances you are better of ungrouping that instance (and perhaps create another group with the Equality)
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
