EQ breaks Parameter in Face Based Family
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
esatis
349 Aufrufe, 6 Antworten
I am facing rather frustrating problem. In Face Based Family, when I put two RP in both sides of the Center RP and lock them with EQ (like I always do), then add Parameter dimension, I cannot input value in Parameter dimension without the EQ RP breaking the EQ lock. Is this a bug ?
Image bellow:
Same setup in Generic Family, everything works as expected:
6 ANTWORTEN 6
Nachricht 2 von 7
Tom_Kunsman
als Antwort auf: esatis
can you post what you do have?
Nachricht 3 von 7
esatis
als Antwort auf: Tom_Kunsman
Sure, I added cleaned up family to my post.
Nachricht 4 von 7
Try placing a Labeled Dimension for half the width and then drive Half Width Parameter value in the Family Types Dialog Box with this Formula:
[Half Width Parameter Name]=P_Width/2
Nachricht 5 von 7
It works!
Nachricht 6 von 7
esatis
als Antwort auf: barthbradley
thank you, yes I know this works, but it is clearly a workaround with one more parameter.
So if I am not missing anything, this clearly is a bug.
Just wanted to gather more info before reporting.
Nachricht 7 von 7
Simon_Weel
Happens to me too - but only in the Family editor. As soon as you load the Family in a project, it works fine.
