Environment Plugin - Planting Parameter
2 ANTWORTEN 2
Nachricht 1 von 3
Cyril_Osano
261 Aufrufe, 2 Antworten
Hi All,
I have a planting family that I downloaded from Environment plug in.
I just want to know how the parameter of this Planting category has been setup.
I have attached the planting family for reference.
The idea I want to understand is when loaded to a project - how does the symbolic line (which created as a nested family) has a different scale parameter aside from the Tree model. And I want to understand the the formula as well which I believe its connected to the scale parameters assign to these family.
Thanks for the help Autodesk community!
[ The subject line of this post has been edited for clarity by @handjonathan Original: PLANTING PARAMETER]
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Cyril_Osano
The "Height" Parameter isn't associated with anything in this Family.  The Material Parameters are though. So, bottom line is: it is what it is. A bunch of geometry put together in such a way as to resemble a 990mm tall tree with a 744mm canopy.
Nachricht 3 von 3
handjonathan
Hi @Cyril_Osano
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
