Entirely Blank Drawing Window
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
1215 Aufrufe, 5 Antworten
After reinstalling Revit I still can not view any of the architecture in my drawings even though it still exists if you hover over it. It is likely a visibility graphics problem that is across any Revit file I create or open. However, I can not remember how I caused it and no simple solution has worked. I am using Revit 2018 and a Windows 10 Home system.
No controls or architecture is viewable within the window.No controls or architecture is viewable within the window.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Any Filters or View templates applied? How about Phasing? If file is not confidential, will you be able to share it so we can have a look.
If this resolves your issue, please click ACCEPT AS SOLUTION.
Nachricht 3 von 6
ennujozlagam
hello, maybe you are in the wrong view? go to your floor plan: level 01, try to zoom to fit or uncheck your use hardware acceleration from options and see if helps. thanks
Nachricht 4 von 6
The Phase filter is on "show complete". In the Visibility / Graphics box the Filter tab shows no filters and the other tabs show every possible selection greyed out and un-editable. And 0 templates are assigned in the View Templates box. I'll check into sharing the drawing tomorrow. Thanks
Nachricht 5 von 6
als Antwort auf: ennujozlagam
The Hardware Acceleration box worked! Thanks!
Nachricht 6 von 6
ennujozlagam
no worries, glad to help. thanks Smiley (fröhlich)
