Enscape will not open with Revit file
9 ANTWORTEN 9
Nachricht 1 von 10
NAUMES
3609 Aufrufe, 9 Antworten
I have been using Enscape with a Revit file for a few months now. A few days ago, Enscape stopped opening with this particular file and causes everything to crash. I have updated my drivers, updated enscape, tried copying the file, nothing works. Sometimes, Enscape will run upon first opening the file, but if I add any other elements to my model after opening it, Enscape will not work. I feel that it may be my Revit file; the first time this happened, something popped up saying my revit file was corrupt. I am not sure what to do.
Beschriftungen (2)
9 ANTWORTEN 9
Nachricht 2 von 10
syman2000
als Antwort auf: NAUMES
Upload the file and see if people run into the same issue
Nachricht 3 von 10
Nachricht 4 von 10
NAUMES
als Antwort auf: syman2000
Here is my file.
Nachricht 5 von 10
NAUMES
als Antwort auf: barthbradley
I just tried this and it did not work, unfortunately
Nachricht 6 von 10
Is it possible that your Enscape license has expired?
Nachricht 7 von 10
syman2000
I tried it and it seems to open the enscape fine from my end. Can you check if you have Revit 2020.2 and Enscape 2.9?
Nachricht 8 von 10
Base12
With larger files and/or lots of materials being assigned, if I don't crop the 3D view Enscape will crash.  Also if the model is a long way from the origin point, cropping the view can fix the problem.
Nachricht 9 von 10
Alfredo_Medina
als Antwort auf: Base12
In that case the problem many not be related to Enscape nor Revit. It could be simply that you don´t have enough space in your C drive for temporary files.
Nachricht 10 von 10
syman2000
Also keep in mind using 4k or 8k texture will make enscape load longer and slower. Often this will lead to your enscape crashing. So keep the file to 2k or 1k for faster and more stable result.
