Enhanced DWG Exporter for Revit - multiple Sheet export - Spaceblocktags
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
1159 Aufrufe, 5 Antworten
Dear Sir or Madam
I have a question about the Enhanced DWG exporter: Is it possible to export more than one sheet / view as a DWG?
I didnt find anything in the documentation about that.
secondly: I use the Enhanced DWG exporter mainly for one reason. It exports the Roomtags as blocks which are very importent for our workflow. Sadly it doenst work with spacetags, although the description say all annotation will be exported as blocks. Any help on this would be very welcomed.
best regards
David
I have a example file attached
5 ANTWORTEN 5
Nachricht 2 von 6
Luiscko
als Antwort auf: Anonymous
Is pretty easy you only need to go to file then export, export CAD click, and then you need to change if you wan to export several sheets, you need to chose in export in sesion view/sheet set and the in the show in list find the option sheets in model, when you have this element select you can check where ever you want  and then click next and Naming-short for faster and unclick in Export views on sheets and links as external references.
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
Nachricht 3 von 6
als Antwort auf: Luiscko
Hi José
Thanks for your detailed Help. What im struggle is not the default DWG exporter. There is an Addon in the Autodesk App Store called: Enhanced DWG Exporter for Revit  Link
Picture.PNGThis Tool is great. It allows to create DWG Blocks from Roomtags, which standard Revit DWG Exporter doesnt support.
But this Tool can only export one sheet at a time, which is really really annoying.
Nachricht 4 von 6
Have you tried to contact the App author and ask the question?
Nachricht 5 von 6
als Antwort auf: ToanDN
"Is there an option to export multiple dwgs at once, because in our projects we have hundreds of views and sheets to export."
Answer from APP-Support:
You should see this feature in the very near future. Please keep checking back for an update to the tool.
"Is it possible to export SpaceTags as Blocks like it works with Roomtags?"
Currently that workflow is not available but they are indeed looking into adding that as a possible export option.
Nachricht 6 von 6
So I guess you just have to wait for the function made available in a future version, or resort to using the built-in Exporter.
