Energyplus simulation result shown in MJ instead of kW, how to change
2 ANTWORTEN 2
Nachricht 1 von 3
174 Aufrufe, 2 Antworten
So I checked other posts already and the only suggestion was to change the "project unit" to "kW" instead of "J". So I used the sample project from Revit and had changed the unit to "kW" and metric under Manage>Project Unit>Energy, and the result is still in MJ.
Would anyone have other recommendations to fix that? Thanks.
2 ANTWORTEN 2
Nachricht 2 von 3
HVAC-Novice
als Antwort auf: Anonymous
MJ (megajoule) is an energy unit. kW (kilowatt) is power. You need some unit of time to convert from one to the other.
kWh (kilo-watt hour) can be directly converted to Joules, MJ etc.
Revit version: R2025.4
Nachricht 3 von 3
So, Energyplus can show result in either MJ or kWh, but I don't know how to show it in kWh using Energyplus in Revit simulation. Anyone knows how? Thanks.
