Hi all
energy simulation keeps failing cause after that i try with a very simple model an than with the sample files but the dialog window told me every time this
"check your internet connection. if the analysis doesn't work report the problem to autodesk subscription support through the subscription center"
I realy don't know how can i fix it
This error may occur due to poor internet connection or low speed internet connection. Try another internet connection. And if the problem continues then there may be energy settings which need to be change.
Thank You
Nitesh Saluja
Hi @Anonymous,
Two possible issues could be happening.
Have you tried updating your software to the latest version?
Which version of Revit are you using?
François-Gabriel
Francois-Gabriel Perraudin
BIM management and coaching
