Energy analysis "Error: Issue: An unrecoverable internal error has occurred"
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
1691 Aufrufe, 11 Antworten
I've been trying to do the energy analysis on my model (by using my friend's pc since she has the complete 2021 version of the software and mine was crashing at the very first stage; I have Revit 2019 educational) but it fails giving me the error "an unrecoverable internal error has occurred" and I can't seem to find the reason. I tried to move the N-W-E-S coordinates to 0,0, by following the guide provided by Autodesk, but it didn't help.
Can you tell me how to fix it? It's really important and urgent for my Master thesis.
Thanks in advance
P.S. I've already tried with the Insight forum but I didn't get any answer back and since I'm getting desperate I thought of trying also here
Beschriftungen (5)
11 ANTWORTEN 11
Nachricht 2 von 12
RDAOU
als Antwort auf: Anonymous
@Anonymous
  1. What is the build number of the Revit 2019 which you are using? below is a screenshot of where you can find it (Click About Autodesk 2019.X >>> Check the top left corner on the pop up window)
  2. To confirm: Did you follow all the step on this article "An unrecoverable internal error has occurred." when running an Energy Analysis in Revit through Insight 360 | Revit Products | Autodesk Knowledge Network
  3. Can you share your model to check PBP/SP/IO ? (If you right unclip the project base point >> Right Click it >>> and select "Move to Startup Location" how far does it move?
Nachricht 3 von 12
als Antwort auf: RDAOU
Thank you for your help!
1) I hope it's the right information:
2) Yes, I have. Unfortunately on the 2019 model (student version) it doesn't go through:
and on the 2021 (on my friend's laptop) it gives me the unrecoverable error mentioned above.
3) The base point goes from here:
to here:
I've attached both models in zip files.
Thanks again
Nachricht 4 von 12
RDAOU
@Anonymous
Both you and your friend need to install latest updates...below is a list of all the updates for 2019 and 2021
Released Revit 2019 Updates & Add-ins | Revit Products | Autodesk Knowledge Network
Autodesk Revit 2021 Product Updates | Revit Products | Autodesk Knowledge Network
You can download them from Account Management or by clicking on the relevant release in the tables of the above links
Nachricht 5 von 12
Thanks again, I tried that too but my version wouldn’t change. I’ll try again. Is it compatible with the student version, too?
So, is this the main problem? If I manage to update the software will I be able to run the analysis? Or is there some other issue with my model?
Thank you so much
Nachricht 6 von 12
RDAOU
@Anonymous
Yes you should be able to get updates and hotfix on educational license
Nothing wrong with your model...the model you sent already had and Energy Model. I deleted it and recreated a new one and I didn't receive any error. Also Accessed the Model on Insight and an Analysis was generated without issues
Nachricht 7 von 12
OmG, thanks.
But unfortunately the only updates available on my profile are these:
Nachricht 9 von 12
@RDAOU I've installed all the updates that you kindly linked but unfortunately now I have this other error:
I don't use proxy connections and my firewall doesn't block any connections. So I don't really know what to do anymore...
Nachricht 10 von 12
esume20124lufe
Can I send my model for analysis please. I’m having issues with mine
Nachricht 11 von 12
esume20124lufe
Tags (1)
Nachricht 12 von 12
facundodemaria88
als Antwort auf: esume20124lufe
im on the same boat brother
assad
