Energy Analysis Not Showing
2 ANTWORTEN 2
Nachricht 1 von 3
enriqueaL4JPJ
827 Aufrufe, 2 Antworten
I am trying to access the Insight 'Energy Analysis' tab within Revit 22 but it's not showing up. I already uninstalled and installed it again. I also checked that the 'Energy Analysis and tools' box was checked at File>Options>User Interface. I am not sure what else to do to solve this problem.
Any help would be appreciated!
Thank you.
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: enriqueaL4JPJ
@enriqueaL4JPJ
Do you have all updates and hot fixes installed? if yes then you might need to perform a clean uninstall
How to Complete a Clean Uninstall of Revit products
See also the following link...It should also apply to 2022
Lighting and Solar analysis icons not showing in the Analyze tab in Revit 2021
Good luck
Nachricht 3 von 3
There is no "Energy Analysis" TAB. Look under "Analyze" TAB.
