Can someone give me a hint what is that? Is it hidden geomtery or what?
I checked several times and haven't found any hidden lines my family file.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Do you have DWGs imported?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
It seems a CAD file in the 3d view
No this is a sketch based on DWG file. Do you suppose this ENDPOINT is a part of DWG?
Can you share the family to check? The 3d model is a DWG file?
That is a ref plane. If you don't want to snap to it in project, set it to Not a reference.
Try to insert the family in a new project because it worked well for me
