Enable to create form element
4 ANTWORTEN 4
Nachricht 1 von 5
siwar.bouaoun
270 Aufrufe, 4 Antworten
I have created an in place mass then reference polylines and the triangles are model polygons
When I have clicked create form this error appeared
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: siwar.bouaoun
Did you actually select something to make a form from?
...shouldn't be that difficult.
Nachricht 3 von 5
siwar.bouaoun
als Antwort auf: barthbradley
Yes I have selected The line and the triangles
Nachricht 4 von 5
Are you trying to do this? If so, your Triangle is not drawn on the correct workplane.  Tab on the Ref. Point to find a different workplane to draw your triangle on.
Nachricht 5 von 5
Are you sure you have drawn the Profile on the Normal Plan to the curve defined by the Reference Plane?
Constantin Stroescu
