Empty/Void mullion
2 ANTWORTEN 2
Nachricht 1 von 3
CT36801
193 Aufrufe, 2 Antworten
Empty/Void mullion
Trying to create seams on a fascia. But "air" shows up as a solid fin:
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: CT36801
Create a view filter to turn them off.
Now think about it, there should be silicon sealant in the gap between glass edges, shouldn't it?  If so, using a small profile for the sealant mullions might do the job without turning them off.
Nachricht 3 von 3
Increase the Transparency factor of the "Air" Material.
...scratch that. I'd use @ToanDN approach if using a System Panel, or - if using a custom Curtain Wall Panel Family - I'd create the "gap" in the Family by insetting the panel geometry from the Right, Left, Top and Bottom Ref. Planes.
...bottom line: Hide Mullions or Remove Mullions. Forget "Air Mullions".  This is BIM not Nike.
