Embedding a Ring Of Windows in a Dome-
Message 1 of 13
Hi:
Have a in-place dome mass- l am attempting to place a ring of windows around the near apex of the dome- l have tried multiple ways. to the extent of two masses - one a void the other a mass- but l lose the top of the dome.. any suggestions - would be greatly appreciated.
Regards
Replies (12)
Message 2 of 13
An image of the dome..
Message 3 of 13
Not too clear what you mean so this is my best guess:
- create the glass dome using a roof by face (glass material/thickness for the roof type), pick the top surface of the dome
- create the frame using in place sweep, pick path (pick the base circle of the roof or the mass)
Message 4 of 13
Have you tried a Wall by [Mass] Face? Regular windows will host to the surface of a Wall by Face.
...or do you mean this?
Pattern-Based Curtain Panels on a Divided Surface.
Message 5 of 13
Hi:
Appreciate the replies, what l am attempting to do is place circular curtain wall at some distance from the apex of the dome, without losing the shape of the dome. I tries to place an opening in the mass, using the shaft opening tool, and then attempted to use two mass one a void at a distance from the apex, and then another generate mass at a distance - but doing it this way.. l lost the shape of the dome...
Message 6 of 13
I can't visualize what you are describing.  Can you post a picture showing what you want it to look like?
Maybe something like this?
Message 7 of 13
syman2000
Hard to know what you want to achieve. Here is a video tutorial how to create dome glass.
https://www.youtube.com/watch?v=zRcZRg_ZnEQ
Message 8 of 13
Hi BarthBradley.. is that a knock down of Boo Bradley from "To kill a Mockingbird" my all time favorite novel...
yes.. that is what l had in mind.. could you please post how to achieve it.. it would be very greatly appreciated...
Message 9 of 13
You mean "Boo Radley"?  I've never had that nickname, but I do love that novel.
Regarding how to model: Create 2 different Masses and place 2 different Wall Types on the Mass surfaces via Wall by Face on the Massing & Site Tab.
Message 10 of 13
Hi Brath:
That's the novel, and many thanks, will finish off my design.
Regards
Message 11 of 13
Hiya:
generate a much easy way of creating a curtain wall ring in a dome-
place a reference line at whatever diameter you want the windows to be at..
create a profile on the face of a point placed on the reference line, it you don't want to use the end points of the line -
pick profile and reference line - and create a solid/orvoid
place curtain wall on face...
design is a hit - now working on the structural engineering of the design...
Message 12 of 13
RDAOU
Why does your reply sound like you are answering yourself but as a second/different person! did you forgot to switch?
Message 13 of 13
solomonwonders99
Community Visitor
Community Visitor
Hello there,
please can you give a detailed explanation as to how you achieved this. I tried it but my windows are not aligned to the dome surface.
Thank you @barthbradley @Anonymous
