Embedded walls: incomplete cut at corner
Kimtaurus
Advisor Advisor
Kimtaurus
I'm having some issues getting the corners to cut properly for embedded walls.
This is the case when the corner is at an angle other then 90°. There's a sliver of wall which remains.
Any idea's how to resolve this, other then creating a void?
This is a rather large project (10 stories several cornerwindows), so I want to avoid having to use model-in-place.
Revit corner Embedded 4.JPGRevit corner Embedded 3.JPGRevit corner Embedded 2.JPG
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
L.Maas
Face based void family?
Edit Profile?
Louis
Please mention Revit version, especially when uploading Revit files.
Kimtaurus
We've used a void family in another project with angled walls, but the problem with this is, you don't "see" the family. This resulted in a lot of error warnings when modifing the walls.
I try not to use edit profile is it affects the wall joins as well.
Maybe this issue needs to be added to the Revit Ideas pages as an improvement.
What are embedded walls?
L.Maas
Using a void family including symbol lines with visibility settings (e.g. only visible in coarse) or set in a 'special' sub-category so that you can make the void family visible when needed?
Louis
An workaround using stacked walls at corners.
Kimtaurus
Thanks for the tip.
Using stacked walls works really well.
