I am creating embedded curtains into a Generic wall which shows great in 3D view, but not showing in Elevation. I am sure that the elevation box is set correctly and I have tried to medium/ fine/ and in wireframe/consistent color, etc, none of them show the curtain.
All other normal curtain walls can be displayed normally in elevation, but only this ones cannot. Do you know what is the reason for this?
I have attached the screenshot of the 3d view and what it looks like in elevation.
Thank you so much for your help!!
Have you change the view depth? Can you check these
1. curtainwall mullion category turned off
2. filter to turn off the curtainwall
3. hidden by element
4. place in workset that is turned off
