While I edit the floor boundary in 3D view and after clicking V, the editing boundary is still visible in pink color, which looks like BUG.
Gelöst! Gehe zur Lösung
Gelöst von marinag7AQRY. Gehe zur Lösung
What's "V"?
Are you saying you are in editing mode and activating VGOs? If so, Why? To try and hide the sketch linework?
Cut and paste the floor in place, edit boundary again and see if it works this time.
@barthbradley "V" is finishing the edit boundary.
After I finished the editing pink line of edit is still visible but I can do other operations.
I found the solution by myself by copying the 3D view and deleting the old one with the problem.
Unfortunately doesn't help, but as I sad copy 3D view and delete the problem one can be solution, but I hope for BUG fixing in future
