AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Elevations
3 ANTWORTEN 3
Nachricht 1 von 4
212 Aufrufe, 3 Antworten
Elevations
i have problem when i draw grids in structure elevation it appears in floor and celling elevations and also when i modify some thing in one of these elevations it happens to all i want to draw in structure elev only and different thing in floor can any one help  my revit version is 2018
3 ANTWORTEN 3
Nachricht 2 von 4
Karol_Piroska
als Antwort auf: Anonymous
well, that is what one would expect. You can duplicate the grid family, call it lets say "structural grid" and in other views turn them off using a filter. Or you can just use some annotation detail family "dummy grid" that will appear only in that view.
Nachricht 3 von 4
Avaris.
Could you explain why you want two different grids?
You can add a parameter or fill existing parameters to make a difference between structural and architectural grid. View filters will then show the 'correct' one for each view. But I am curious why you want two different grids.
Nachricht 4 von 4
als Antwort auf: Avaris.
Sorry I made a mistake I understood it from my teacher that in the case of drawing house rules we draw in FLOOR PLAN AND WHEN WE DRAW GRIDS WE DRAW IT IN STRUCTURAL PLANS AND I DID NOT KNOW THAT I CAN DO ALL OF THIS IN SAME PLAN I AM REALLY SORRY AND THANK YOU FOR REPLYING
In Foren verƶffentlichen
