Elevations inconsistent between views
14 ANTWORTEN 14
Nachricht 1 von 15
cbt990
532 Aufrufe, 14 Antworten
I am seeing an inconsistency with some of my spot elevation annotations.
In plan view, the lowest extent of the ramp reads at 91.56, while the slab just beyond it is at 92.12:
But things look right in elevation:
Revit is amazing
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: cbt990
Spot Elevations are view-specific. So maybe the annotations are not referencing the exact same point.
Nachricht 3 von 15
syman2000
It did that on mine as well. This is why I don't put spot elevation on ramp and rather place flat slab elevation and add slope up to the other flat slab. Also ramp is the worst tool and I would replace it with slab with slope that mimic ramp to get the proper spot elevation reading.
Nachricht 4 von 15
cbt990
als Antwort auf: barthbradley
i have set both elevations to reference the same elevation level.
Revit is amazing
Nachricht 5 von 15
Aren't you using 2022?
Nachricht 6 von 15
cbt990
2021.1.5. Why?
Revit is amazing
Nachricht 7 von 15
That's not what I meant.  I'm talking about the spot the Spot Elevations are referencing. Are both View's Spot Elevations referencing the EXACT SAME SPOT?  If so, how do you know?
Nachricht 8 von 15
cbt990
als Antwort auf: syman2000
This seems to have worked.
Revit is amazing
Nachricht 9 von 15
cbt990
Except now I can't place an elevation tag on the new ramped floor:
Revit is amazing
Nachricht 10 von 15
@cbt990 wrote:
2021.1.5. Why?
Because you can't place Spot Elevations on Ramps in Plan View before 2022.
Nachricht 11 von 15
cbt990
So the way i have my project set up is as follows:
Sea level is a level which has linked CAD files and surveys. The elevation is (0' - Finished Floor elevation')
To get the ramp spot elevations to read correctly, i created an extra reference layer, which is not a solution I wanted to introduce into the model:
You're telling me that this problem is fixed in 22?
Revit is amazing
Nachricht 12 von 15
cbt990
it's very strange because as I drag my elevation tag across the ramp (ensuring only to move laterally), the elevation seems to change.
Can't explain this.
Revit is amazing
Nachricht 13 von 15
91.56 is the elevation of the floor or whatever element under the ramp, not the ramp itself.  Not convinced?  SImply hide the ramp in view and see if the spot elevation goes away.
Nachricht 14 von 15
What problem???  I'm totally confused now.  I thought this was about an inconsistency between a Spot Elevation shown in a Plan View and one shown in an Elevation View.    Now you've added Links and Survey Point and Levels into the mix.
Nachricht 15 von 15
syman2000
Try isolate the newly created sloped floor. Then see if you are able to add spot elevation.
