Elevations don't show the model, only levels
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
jhsdb
646 Aufrufe, 4 Antworten
Hi, I'm a fairly competent user but I'm stumped. I made a template from an old project and must have accidentally deleted the elevations from the project browser. No problem, I created new ones. I've checked the crop region, vis/graphic overrides, hidden elements, view range, etc and still can't see anything in elevation views. So far I've only drawn walls, grids and added one component, a countertop. Weirdly, I can only see the countertop in every elevation. Any ideas??
Beschriftungen (3)
4 ANTWORTEN 4
Nachricht 2 von 5
hmunsell
als Antwort auf: jhsdb
what is the discipline for the elevation set to?
if it is set to Structural, Casework will show but Architectural walls will not. worth a shot.....
Howard Munsell
Nachricht 3 von 5
Check your View Phase
Nachricht 4 von 5
jhsdb
als Antwort auf: hmunsell
did the trick, many thanks!
Nachricht 5 von 5
jhsdb
als Antwort auf: barthbradley
I haven't created phases yet on this project but good idea. The previous reply about discipline was the ticket. Thanks!
