Elevation - wall transparency issue
2 ANTWORTEN 2
Nachricht 1 von 3
Normli
236 Aufrufe, 2 Antworten
I have a issue with an elevation view, where the wall transparency seem to be on.  I can't seem to find out which setting is causing this to be on.  I check the graphic display setting and the visibility/graphic override setting.  Please provide some suggestions.  Thanks
2 ANTWORTEN 2
Nachricht 2 von 3
Sean_Page
als Antwort auf: Normli
Is it painted with a transparent material?
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
Nachricht 3 von 3
anze.kumar
Does  visibility/graphic override setting have anything in Transparency?
Maybe you have Wireframe turned on?
