elevation views not showing
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
23156 Aufrufe, 3 Antworten
i am new to revit and am doing a tutorial that shows the elevation views in the pane on the left.  all i see on the left is:  floor plans, cieling plans, and 3d views.  can someone help?  is it hidden for some reason?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
What Template did you use to start the Project?  If you are sure they are not there, they could be easily created.
Go to View Tab and see:
..You sure you don't see this?  Maybe the Category isn't expanded. Press the "+" symbol if so.
Nachricht 3 von 4
als Antwort auf: barthbradley
thank you.  yes i did that and works great.  however it is strange that at the beginning of the new project it actually shows elevations on the left pane.  then as i add walls the default elevations disappear  and i have to recreate them.  this is really annoying.  any idea why it would do this?
Nachricht 4 von 4
You could have deleted the elevation symbols on the plan view and that would delete the actual elevation views from the project browser.
