Elevation view tags
Elevation view tags
yes_and_no
Elevation view tags
yes_and_no
I m sure you guys have ran into this situation where you have elevation view tags pointing to different sheets, resulted in no reference at all (left).
Pls save me the work-around of making 4 different tags.
I know somewhere someone already made similar tag as shown on the (right).
Wd you point me there if you know ? Thanks in advance.
- Edit the elevation pointer family and add Sheet number to the label
- Edit the elevation marker family and remove Sheet number label
Save them as copy so that you can create a different elevation type for only this situation.
With that said, I would just place them as different elevation markers altogether and use the standard one with the sheet number inside the circle.
yes_and_no
Thanks Toan. I made it. Not perfect visually, but good enough for me.
Extra parameter for North arrow rotation seems not allowable in this tag kind, perhaps yo
u can help ?
No instance parameters work in elevation families. You could create different types for different angles, or place a north arrow separately over the elevation marker in view in project.
yes_and_no
Thanks, I went with the first suggestion with a downloaded family.
Inside the family itself, the triangle has center point at the center of the triangle. However when I bring it in the model, the insertion mark is shown at somewhere else, making angle parametric adjustments gone off center everytime. How to fix this ?
I also learn from Rv19, (where I worked while ago), that you can lock (not pin) two families together, but I forget. Does anybody remember how ? Thx.
