This is my first post. ![]()
I'm working on a rehab project.
I have an existing wall and windows. I intend to keep the existing wall, demolish the existing window and then I enter a new window.
When I use the "Hidden line" in the elevation view only the intersection of the two windows appears to me. (attached file). In doors it works great but in widows gave this error.
The phase that I intend to see is the Existing, New and Demolish.
How do I solve this situation? Any ideas?
Thanks for help in advance
If you turn off walls, they show up.
So your wonderful solution is to present the elevation with the hidden wall ... and the other walls that are behind hide them too? So clever! It may be best to use Wireframe in display graphics. Thanks for your solution.
In this real world I want to present the elevations with the existing, the demolished and the new phase all in the same view.
My post was obviously not a solution but rather a bit of guidance for you to solve it yourself.
Think about it. If the wall is hiding them, how would you go about being able to see them through the wall? Unless the wall is transparent, you would need an opening, right?
Good luck!
