Elevation value of topography point is 25m lower than the actual elevation
1 ANTWORT 1
Nachricht 1 von 2
402 Aufrufe, 1 Antwort
I successfully created a topography with accurate elevations and coordinates however when I wanted to define the 'graded Region' and change elevation of the points, I figured all the points are consistently 25 m below the actual value.
Surprisingly, in sections and when I link other CAD files, the elevation is correct. It is only the point that shows incorrect value.
I hope someone can tell me why.
Beschriftungen (1)
1 ANTWORT 1
Nachricht 2 von 2
RDAOU
als Antwort auf: Anonymous
@Anonymous
Because the elevations of the Toposurface Points are Absolute...They relate to the level the topography was first created/hosted to.
When you place new points you are given the option to either place them as Absolute of Relative to an existing toposurface.
Edit: check this link maybe it is of interest to you https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2019/ENU/Revit-Troubleshooting/files/GUID-6A655821-3E03-4452-99A8-E74BFF677B06-htm.html
