Elevation tool greyed out in Revit 2016
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
hannah.m.skinner21
1584 Aufrufe, 2 Antworten
Hi, I started learning Revit about 20 minutes following a youtube tutorial.  The tutorial shows you how to place elevation views, and using those views creating new building levels.  The only problem is when I try to follow along the elevation tool is greyed out.  I have no clue why. Any suggestions would be very much appreciated.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: hannah.m.skinner21
You are probably in a 3d view. Go to a floor plan view then the tool will be available.
Nachricht 3 von 3
hannah.m.skinner21
als Antwort auf: ToanDN
Thanks for your help! That seemed to be the problem.
