Elevation Tag Text Placement
Hello there, I am having difficulties rotating the detail number on the elevation tags.  The tag to the North is showing correctly, however; the other elevation tag detail numbers have moved.  I cannot seem to locate where to make this change.  Please see attachment for better idea.  Thank you in advance!
Sahay_R
In you browser under Families >> Annotation, find the elevation tag and right click on it ans select Edit. That will take you to  the family.
In the family, click on one of the text labels. Do the properties of the label look like this?
If not, then can you share the family?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Thank you for your response.  Yes, the label looks like that!
Sahay_R
Can you share the family?
Rina Sahay
See attached family named "Elevation Mark Body_Circle".  Thank you for your assistance rashayUZMK9.
See revised file.  Please note that this only works for single elevation mark.  For multi-elevation mark, such as Interior elevations, I recommend to use the OOTB Interior Elevation and pointer mark, where the detail number is outside of the pointer.
