Why does my elevation not have the end grabers that can adjust the width of the elevation view?
They should be blue does that allow for width adjustments:
Gelöst! Gehe zur Lösung
Gelöst von jay_colcombe. Gehe zur Lösung
Elevations do not have this feature like Sections.
The elevation width is controlled by the Crop Region
Can you go to elevation and adjust the elevation crop?
This is incorrect. Here is a comparison where you can see the end grabbers as well as the side outlines of the view box:
If you do not crop the View which elevations don't typically need as you usually just edit the Elevation Crop boundary you do not get the Segment Handle
If you do Tick "Crop View" the view it acts more like a Section View (and even refers to a Section) and hence the Segment Handle appears
