Elevation mark changes in all plans
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
1988 Aufrufe, 10 Antworten
Hi, Can I move elevation mark in one plan view without changing the location in other views? any help would be appreciated.
10 ANTWORTEN 10
Nachricht 2 von 11
David_Knight
als Antwort auf: Anonymous
Sadly, no.
I use view references to deal with this problem.
I made a view reference that looks the same as my elevation tags, then hide the actual elevation tag and place the view reference in it's place.  Then I can move it wherever I need it.
Not ideal.
Nachricht 3 von 11
als Antwort auf: David_Knight
How do make view reference?
Nachricht 4 von 11
David_Knight
View Tab -> View Reference
"View Type" set to: Elevation
"Target View" set to the view you want it to link to.
The view reference family will likely not look how you want it to.
Try the one I have attached.
Nachricht 5 von 11
Yes you can. Select the Mark, not the arrows, and drag it to where you want.
Nachricht 6 von 11
David_Knight
als Antwort auf: ToanDN
Doing that will move it on both plans.  I just triple verified this.
Here is a screencast showing it happening.
> Elevation markers are red.
> View references are black.
View references are the only way around the problem I am aware of.
Nachricht 7 von 11
Yes you are entirely correct.
Nachricht 8 von 11
@Anonymous
You should mark @David_Knight post as the solution and unmark mine.  Thanks!
Nachricht 9 von 11
David, thanks for the tag. Should I create 4 types(UP, Down...), or is there any check marks that I can use for UP, Down...
Nachricht 10 von 11
David_Knight
You need 4 types for the family unfortunate (unless someone can find a way to improve my family).  There is a parameter that controls the direction for each family type.
You also need 4 types of view references.  Each referencing the family with the matching type created.
So make a View Reference named "Up" and have it reference the family that is named (and checked) "Up" as well.
You can probably copy mine in if you copy them all at the same time and reference a drafting view or something.
Nachricht 11 von 11
Seychellian
Has anything changed on this since 2017?
