Elevation looks like section
7 REPLIES 7
Message 1 of 8
michalcapek4
1459 Views, 7 Replies
Hi I have a 3d drawing in revit with multiple elevations and only one elevation has this problem. It comes out as a section instead of an elevation
can you help me with this?
Mike
7 REPLIES 7
Message 2 of 8
move the elevation marker (select with window/cross and drag it) outside the building..
Now ,South Elevation it will be OK
Constantin Stroescu
Message 3 of 8
Thanks alot from which place are you removing the triangle - floorplans?
Im asking because i can't find the triangle somehow, and can't unhide it
Message 4 of 8
I've just removed the triangle as you've shown inside the structural plan - F1 and it it still shows a section
Message 5 of 8
Do not remove the triangle ! You can erase the elevation!
 Select both tringle and rectangle ( both of them ) and move them outside the building , as in my second screenshot
Constantin Stroescu
Message 6 of 8
In Floor Plan find the Elevation-Views markers ( a rectangle and a triangle  here) and drag them outside the building - Southward for the South View.
Constantin Stroescu
Message 7 of 8
It looks like i have some strange setting or something because i've done that but i still see a section. I will sent screenshots
Message 8 of 8
ennujozlagam
in reply to: michalcapek4
hello,i just move your elevation view and adjust your far clipping same as what @constantin.stroescu did. i attached your file back. 1a.JPGthanks
