Elevation filter only removing arrow
5 ANTWORTEN 5
Nachricht 1 von 6
Anonymous238
574 Aufrufe, 5 Antworten
I'm trying to remove proposed elevations in a demolition plan which has demolition elevations. I made a filter for elevations with phase filter that contains "Complete" to hide those elevations but Revit only removes the elevation tags arrow and not the entire tag. How to fix?
5 ANTWORTEN 5
Nachricht 2 von 6
jay_colcombe
als Antwort auf: Anonymous238
Elevations are made up of multiple elements (Elevation Tags + Elevation View) so your Filter would need to include both of these in the Filter
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 6
Anonymous238
als Antwort auf: jay_colcombe
I'm talking about VG settings. I already have a filter like this that works for filtering the demolition elevations in my proposed plans. I'm trying to do the reverse as stated above and it only takes out the arrow which makes me think the phase filter isn't enough of a parameter to hide an elevation tag.
Nachricht 4 von 6
jay_colcombe
Are the Elevation Views in the Correct Phase?  Select the Demo Elevation and change its Phase  to Demo, in the Plan View select another Phase and they should be hidden without the need for a Filter as there is a rule where view are hidden in Phasing where mismatch between plan and elevation even using phase filters
Or just hide the Tags all together? or Select > Right Click Hide in View
Can you take a screenshot to explain in more detail to assist?
Jay Colcombe
Nachricht 5 von 6
jay_colcombe
If you just wanted to use a Filter as the Plan and elevation are on the SAME Phase
The issue is you cannot apply a phase to the Marker (Circle 12mm) Element so you have to reference it another way!
I would probably use View Name as the Second Filter for the Circle as you can specify the Exact View Reference and leave those you want
Jay Colcombe
Nachricht 6 von 6
handjonathan
Hi @Anonymous238
Thanks a lot for posting your question to the forums!   Has the solution suggested by @jay_colcombe helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
