I have a problem with the line view and printing from Elevation and Section views.
I want all the lines to look exactly like in a plan view (black, normal width), because now the section and elevation views show very thin lines although I already tried to change manually the thickness of the lines for curtain wall elements and floor to see if something would change, but it didn't change anything.
When printing out the views on paper all the lines have some kind of red dotted lines over all the black lines and I can't explain why.
Here on the example picture you can see the difference between plan line types and section line types. In the section views also the dimensions show in a normal width and black, so it should be connected somehow to the template, but I can't find the problem.
Gelöst! Gehe zur Lösung
Gelöst von infoV5VYV. Gehe zur Lösung
You can edit the visualization of the lines in Object Styles
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
In the Object Styles window of the section view I have the same line properties for walls etc. as in plan view template. That doesn't seem as the problem in this case.
Object Styles are fot all the project not only for a view. Have you checked your template? If you make a view without template works?
hi,
no, Even if I choose <none> template, the lines are still very thin, not black and not so visible when printed out...
After a long time of clicking everything in the templates I found that turning off the viewing depth all the lines show black and also print out wide enough to see ![]()
Sorry to don't reply to you yesterday, but glad to read you have the solution! Congrats!
