Elements showing on floor plan that shouldn't be
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
803 Aufrufe, 2 Antworten
I'm having an issue where walls/ceilings/light fixtures that are above my cut plane and above my top view range are showing on my floor plan in a light gray. They are all from the same levels (I'm not seeing things from the second floor on the first floor for example). I've checked the families themselves and none of them have symbolic or model lines that should show up on the floor plans. I've messed with my view range and that hasn't alleviated the issue either. If anyone can offer some advice that would be fantastic.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Change Underlay Base level to None.
Nachricht 3 von 3
als Antwort auf: ToanDN
Thank you very much. That did it.
