Elements of dwg import is rotated.
I'm having a problem with some dwg files that I'm linking into Revit. (I've received them from the same person, so the problem could lie with them)
When I link the file into Revit, some objects/blocks are rotated.
The example below I off a truss. In AutoCAD it looks fine, in Revit the top profile is rotated 90°.
Anyone had a similar problem with dwg files?
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
