Elements not visible, plan region
Good day,
We have a problem in our revit project.
It is a project of the same houses, in different heights.
The houses are linked in the project, on different heights. We make them visible with plan regions.
It is working, but some elements are not visible, but they are in the linked file.
Some houses the stair is visible and some houses not.
This also applies for the furniture. On the base level is sometimes the bed visible, but the bed is standing on the first floor
We have checked the view range, the filters, everything.
But they show up incosistent
thanx for the support!
Greetings,
Geurt
I wouldn't recommend to use plan region for this, use link view instead, this will make sure every link looks consistent.
claudio.chaverri.sievert
There can be many causes for this problem. The following Ideate Blog post has 33 items to check:
Missing Something in a Revit View? 33 Steps to Find Stuff
Here is an article with few more items you can check:   Element or elements missing from view within Revit
__________________________
Claus Chaverri-Sievert
Technical Support Specialist
San José, Costa Rica
www.autodesk.com
hpascacio
Observer
Observer
Better late than never, I have discovered that if any part of the Boundary of the Region Plan touches the geometry of the element, the element will not appear. Try to move the boundary of the element a few tenths of a millimetre away so that it appears.
Greetings.
