10:30 AM
So I have an issue with locating the elements that are giving me a duplicate "Type Mark" value in the Warning dialog box. This is what I have tried.
- Went to the Warning dialog box and checked the box next to the element but the Show button and More Info are greyed out
- Used the ID for the element to Select by ID.
- After clicking Show, I get a message that says "No Good view could be found"
- Clicked Ok, element was highlighted and saw info of the element in the properties but all fields were greyed out and I couldn't use the drop down in the properties to change the element (type, size, etc)
- Created a schedule to try to locate the element by Family, Type, Type Mark, etc and couldn't be located in the schedule.
- Took a look at the journal file just to see if I could ascertain anything unusual.
- Workset is on
- Created a new Default 3D View and locate the element to eliminate any visibility issues
Any ideas? Thanks in advance.
