I am having an issue, where all of the elements are displayed as wireframe, and I can't get them to display properly (see screenshots).
I am attempting to setup some detail views of some casework. When I set them up, they looked correctly. The next day, I opened up the project and everything in the view appears to be wireframe. I've checked visibility graphics for any overrides, the elements themselves for any instance overrides and nothing. I was able to fix it by toggling the "Far Clipping" parameter to be "Clip with Line" in the view template and applying it, then resetting it.
But now it is back, and the previous fix doesn't work. And other people in the project can see the issue on their end.
The other views in the project display correctly for me. I am thinking it is something with the project, or the view type, or these individual views, or perhaps the families. However, the other instances of this family are showing up correctly.
Any suggestions would be helpful! Thank you in advance!
For confidentiality reasons, I cannot share the model, but I can try to recreate the error in another model.
It is a cloud-workshared model. Windows 10, and I am using a remote connection.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
