AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Elements cannot stay connected/joined
2 ANTWORTEN 2
Nachricht 1 von 3
shershahbacha9
335 Aufrufe, 2 Antworten
Actually, i wrote a Dynamo script that make walls on window reveals and its doing. But there comes a problem in Revit. When i run script, this warning window (as shown in Pic 1)comes which says "Elements cannot stay joined/connected" which probably means  that wall cannot go till it which touches the window as shown in picture 2 . Because the wall has to go till window face but after i click "leave connection between elements" on this warning window, the finish wall is little short and doesnt touch window face. Any solution for it becasue i want walls to go till window face as scripted.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: shershahbacha9
I'm not understanding what you would like help with. The Dyn Routine?  Is the error thrown when you perform the actions "manually" - without using Dynamo.
Nachricht 3 von 3
shershahbacha9
als Antwort auf: barthbradley
i will try this in Dynamo later but wanna know whats the problem when i create walls on window reveals. why comes this error that elements cannot be connected/joined. Actually the elements that could not be connected are this Finish wall and that already present conctrete wall.
In Foren verƶffentlichen
