Some time we need to edit some reference plane or parameter to change the position or geometry of some elements. The problem is that when you do that you could change also some other elements inadvertently. Is there a way I can list the elements linked to that reference plane or parameter?
Unfortunately, Revit doesn’t offer a direct way to produce a report or list of linked elements within the Family Editor
you may however, Check for any alignment locks (indicated by padlocks) and constraints that might indicate which elements are tied to this plane. For complex families, maintaining good naming conventions and organized constraints helps make this process easier.
If you try to make a reference for each element, it takes more work, but it is more accurate and easy to upgrade, or you can create parts of the family in a nested family and etc.
If you post the family, maybe it can be easier to commented.
