We are using Navisworks for clash detection. I want to be able to use the Element ID visible in the Navisworks clash and Revit, to build a full schedule of linked model elements to assist in finding the elements with the element IDs. Is it possible to show the element IDs from linked models in a schedule?
Not in a native schedule, not even for elements in the active file, let alone a linked model. You'd have to look at exporting data from Revit via Dynamo most likely.
Steve Stafford
To get them back into a schedule you'd either need a tool like BIM Link or write your own code to do what it does, which is to build a schedule in the header portion of a schedule with data from an external file (Excel usually). Since Element ID isn't a value that can be in a schedule natively you'd have to transfer that value into another parameter so it can be included in the schedule.
Steve Stafford
