Electrical Switch Symbols Huge
5 ANTWORTEN 5
Nachricht 1 von 6
HEVNBND
1317 Aufrufe, 5 Antworten
Just getting started with Revit and If I add in say an Electrical Switch it is very large in the 2D view. I attached a screenshot.  As you can see in the picture the switch is larger than the light fixture. Revit Switch Symbol.jpg
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: HEVNBND
Use a large scale for the view.
Nachricht 3 von 6
HEVNBND
als Antwort auf: ToanDN
Thanks. How do I do that?
Nachricht 4 von 6
The view has a view template that sets the scale to 1/8" = 1'. You could set by the template to none and you can change the scale to 1/4" or whatever you need. However, the template is there for a reason. If you work with a team then talk to someone in charge of standards.
By the way, those symbols look normal for a 1/8" scale plan.
Nachricht 5 von 6
FWIW: Symbols are annotative, just like Text.  When you use 1/8" Text Type, it is printed at 1/8" no matter what the View Scale.
Create an Annotation Symbol Family | Revit 2021 | Autodesk Knowledge Network
Nachricht 6 von 6
s.borello
Because the switches are annotative... lights are not.  Try changing the scale of your view to 1/4" as @ToanDN suggests.  You could edit the anno switch family and make it smaller, but I would not do that... your symbols look fine by the way for an 1/8" scaled drawing.
