I am trying to create a 3d electrical component (eg GPO, data outlets), and associated tags.
We have standard 3d electrical components, which have the symbols shown in plan (as well as face plates in 3d/elevation). The main problem is that I cannot manipulate the orientation of the symbol in plan. This makes it hard to read when we have components next to each other at 1:100 scale as the annotation cannot be manipulated separately to the 3d element.
I am thinking that it would be best to:
Not being a long time user of Revit (or a computer programmer) I'm unsure on:
I've spent a couple of hours spinning in circles, nobody in the office knows how to do this and I can't seem to find a specific example online... Any help/insight appreciated. Thanks!
Hello Justin,
Did you ever get a fix for this.
You need to create an offset parameter in the family which will move the 2D annotation symbol in either direction away form the outlet next to it, you can create another offset to move the 2D symbol out from the other symbol, if for example you have outlets one above the other.
I have attached a few mages.
Regards
Thanks for the feedback. We had a block with a similar way of adjusting offsets, but i was hoping for a quicker, graphical way of manipulating the symbols, similar to a tag but instead of text you would have the standard symbols, if that makes sense.
