when I set cut plane to 4ft the light fixtures are not properly visible and light switches are visible, but when Its set at 5ft, lighting is good and visible, but not the switches
Did you have a question? When you decide to ask, make sure you include all of the relevant information.
Ceiling Plan? Set your View Depth Level to Unlimited. That solve?
...wait a minute. Somthing doesn't compute here. Light Fixture DO NOT show when you lower cut plane to pick up Switches, but DO show if you raise cut plane above Switches. I'm thinking the Light Fixture Family is using the Model Line Trick. If so, edit Family and make line longer. The idea is to make it long enough to intersect with the 4' View Range cut plane.
