I was looking for the most efficient method for making a monolithic staircase for a case shown in the 1st image stair1.jpg, where you have a step in the landing, and that would go multi-storey and give such a seamless output as shown in 2nd image stair2.jpg.
For the first riser to extend below the first step, I learnt it from @ToanDN in this solved post. Please give him kudos if it has helped you.
Many Thanks...
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
There is not any problem if there are more than 1 steps in that mid-landing. But I haven't been able to create it if landing is containing single step.
Try the sketch mode in the stair by component command. I think if you draw a riser in the middle it should be fine.
@Anonymous hi!
You will be one step short which you will need to add either at the beginning or end of the other two flights. (To do that you need to edit the stairs if you have already placed it)
In principle; I 99% or the times I do not use "End with Riser"...I level the last Tread with the floor level then join the stair with the floor/slab...Why?? for many reasons but that's another topic ![]()
I will add the screencast once it is uploaded EDIT: Screencast Added
@Anonymous
LoL someone might say I have sent you lol...but hey thanks; what you said there is something pleasant to hear
for a change cuz lately I've been told otherwise (I am deemed a disruptive source of annoyance and customer service aren't pleased with the image I transmit lol among other stuff)
Anyhow you should be careful what you say here they might not be happy with it... and God being brought into it; some expert elites has no sense of humor and might report you for blasphemy lol
@Anonymous wrote:
Hey @RDAOU,
I have been going through your other posts as well. There is an "Expert Elite" badge. But there should be a "God" badge for you. Many thanks...
